AddDim3PointAngular method
Adds a 3 Point Angular dimension object.
Syntax
objectVariable = object.AddDim3PointAngular(AngleVertex, FirstEndPoint, SecondEndPoint, TextLocation)
Where:
     AngleVertex is a Variant identifying the center of the circle or arc, or the common vertex between the two dimensioned lines;
     FirstEndPoint is a Variant  identifying the point through which the first extension line passes;
     SecondEndPoint is a Variant identifying the point through which the second extension line passes;
     TextLocation is a Variant identifying the location of the text.
