AddDimAligned method
Adds an Aligned dimension object.
Syntax
objectVariable = object.AddDimAligned(ExtPoint1, ExtPoint2, TextLocation)
Where:
     object is one of the ModelSpace or PaperSpace collection objects or a Block object;
     ExtPoint1 is a Variant identifying the first endpoint of the extension line;
     ExtPoint2 is a Variant identifying the second endpoint of the extension line;
     TextLocation is a Point object identifying the location of the text.
