Adds a Radius dimension object.
Syntax
Where:
object is one of the ModelSpace or PaperSpace collection objects or a Block object;
Center is a Variant identifying the center point on the arc;
ChordPoint is a Variant identifying the point on the circle or arc to attach the leader line;
LeaderLength is a double-precision variable specifying the length from the ChordPoint to the annotation text or dogleg.
© Menhirs NV. All rights reserved. |
