AddLeader method
Creates a leader and adds it to the drawing.
Syntax
objectVariable = object.AddLeader(Points, Annotation, type)
Where:
     objectVariable is a Leader object;
     object is one of the ModelSpace or PaperSpace collection objects or a Block object;
     Points is a collection of points defining the leader line;
     Annotation is a String of text or a dimension to be associated with the leader;
     type is a Long integer representing one of the following LeaderType constants:
0     LeaderLineWithNoArrow
1     LeaderLineWithArrow
Examples...
AddLeader method example
