Sub AddRay_Example() ' This example creates an infinite half line and adds it to the drawing using the ' AcadRay method. Dim myRay As AcadRay Dim Pt1(0 To 2) As Double Dim Pt2(0 To 2) As Double Pt1(0) = 2: Pt1(1) = 2: Pt1(2) = 0 Pt2(0) = 1: Pt2(1) = 3: Pt2(2) = 0 Set myRay = ThisDrawing.ModelSpace.AddRay(Pt1, Pt2) ThisDrawing.Application.ZoomExtents End Sub
© Menhirs NV. All rights reserved. |
