AddTolerance method
Creates a Tolerance entity.
Syntax
objectVariable = object.AddTolerance([Text], [InsertionPoint], [Direction])
Where:
     objectVariable is an Mtext object;
     object is one of the ModelSpace or PaperSpace collection objects or a Block object;
     Text is a String representing the tolerance text;
     InsertionPoint is a Point object representing the location to insert the tolerance;
     Direction is a Vector object representing the direction of the tolerance symbol.
Examples...
AddTolerance method example
