AddTorus method
Adds a torus given the location, torus radius and tube radius. The torus object is created as a polygon mesh.
Syntax
objectVariable = object.AddTorus([Center], [TorusRadius], [TubeRadius])
Where:
     object is one of the ModelSpace or PaperSpace collection objects or a Block object;
     Center is a Variant representing the center point of the torus;
     TorusRadius is a double-precision variable representing the radius of the torus (distance from center of torus to center of tube);
     TubeRadius is a double-precision variable representing the radius of the tube.
Examples...
AddTorus method example
