Close method
Closes the document and all associated windows.
Syntax
objectVariable = object.Close([SaveChanges], [File])
Where:
     object is a Document object.
     SaveChanges is an optional Boolean variable indicating whether to save changes made since the last save (A value of True saves the changes, while a value of False does not);
     File is an optional string naming the file to be saved.
Examples...
Close method example
