GetAngle method
Allows the user to specify the angle on the graphics window.
Syntax
object.GetAngle([Point], [Prompt])
Where:
     object is the Utility object;
     Point is a Variant representing the base point for the angle;
     Prompt is is a String prompting the user to pick the angle.
Examples...
GetAngle method example
