GetBoundingBox method
Returns the minimum and maximum point of an entity's bounding box: the box that encloses a specified entity.
Syntax
object.GetBoundingBox(MinPoint, MaxPoint)
Where:
     object is a Drawing Entity object;
     MinPoint and MaxPoint are Variant (array of doubles) representing the lower-left and upper-right corners of a box enclosing a particular object.
Examples...
GetBoundingBox method example
