GetCorner method example
Sub GetCorner_Example()
' This example uses .Utility.GetCorner; it provides a base point
' and prompts the user to select a second point to make a rectangle.
    Dim otherCorner As Variant
    Dim basePCorner(0 To 2) As Double
    basePCorner(0) = 2#: basePCorner(1) = 2#: basePCorner(2) = 0#
    otherCorner = ThisDrawing.Utility.GetCorner(basePCorner, "Enter Other corner: ")
    Dim nDec As Integer: nDec = ThisDrawing.GetVariable("LUPREC")
    Dim sBuf As String
    sBuf = "The point for other corner was picked at:" & vbCrLf
    sBuf = sBuf & Math.Round(otherCorner(0), nDec) & ", "
    sBuf = sBuf & Math.Round(otherCorner(1), nDec) & ", "
    sBuf = sBuf & Math.Round(otherCorner(2), nDec)
    MsgBox sBuf, , "GetCorner Example"
End Sub
