GetGridSpacing method example
Sub GetGridSpacing_Example()
' This example finds the current Snap spacing.
' First, find the current active viewport
    Dim viewportObj As AcadViewport
    Dim XGrid As Double
    Dim YGrid As Double
    Set viewportObj = ThisDrawing.ActiveViewport
    ' Turn on Snap and reset the viewport.
    viewportObj.GridOn = True
    ThisDrawing.ActiveViewport = viewportObj
    ' Find the current Snap spacing
    viewportObj.GetGridSpacing XGrid, YGrid
    MsgBox "X Grid Spacing = " & XGrid & " Y Grid Spacing = " & YGrid
End Sub
