Adds a new Block Insert object.
Syntax
Where:
InsertionPoint is a Variant representing the point at which the block will be inserted;
object is one of the ModelSpace or PaperSpace collection objects or a Block object;
BlockName is a string representing the name of the block;
XScale, YScale, and ZScale are double-precision variables (or values) representing the scaling factors for the drawing along each coordinate plane;
Rotation is a double-precision variable (or value) representing the rotation angle (in radians) for the external reference.
Examples...
© Menhirs NV. All rights reserved. |
