PlotToFile  example
This example plots the current drawing to a file.
Sub Example_Plot()
    Dim oPlot As AcadPlot: Set oPlot = ThisDrawing.Plot
    Dim sPlotFileName As String: sPlotFileName = "c:MyPlot01.plt"
    Dim bPlotOk As Boolean: bPlotOk = oPlot.PlotToFile(sPlotFileName)
    MsgBox (IIf(bPlotOk, "Plot succeeded", "Plot failed"))
End Sub
This example plots the current drawing to a file while using a named plot configuration.
Sub Example_Plot02()
    bPlotOk = oPlot.PlotToFile(sPlotFileName, "Adobe_PDF.pc3")
End Sub
