Rotate method
Rotates an object or selection set.
Syntax
object.Rotate(BasePoint, RotationAngle)
Where:
     object is a Bricscad entity;
     BasePoint is a Variant (three-element array of doubles) representing the point about which objects will be rotated;
     RotationAngle is a double-precision variable (or value) representing the angle in radians.
Examples...
Copy method example
