Select method
Selects objects within the rectangle specified by two points, and adds them to the SelectionSet.
Syntax
object.Select(Type, [Point1], [Point2], [FilterType], [FilterData])
Where:
     object is a SelectionSet object;
     Type is one of the following SelectionSetType constants corresponding to the various selection modes:
     acSelectionSetAll = 11
     acSelectionSetCrossingCircle = 3
     acSelectionSetCrossingPolygon = 0
     acSelectionSetCrossingWindow = 6
     acSelectionSetFence = 12
     acSelectionSetInsideCircle = 5
     acSelectionSetInsidePolygon = 2
     acSelectionSetInsideWindow = 8
     acSelectionSetLast = 10
     acSelectionSetOutsideCircle = 4
     acSelectionSetOutsidePolygon = 1
     acSelectionSetOutsideWindow = 7
     acSelectionSetPrevious = 9
     Point1 and Point2 are Variant (three-element array of doubles) defining a rectangle for those applicable selection modes;
     FilterType is an optional parameter for specifying how to filter data selection;
     FilterData is an optional parameter for specifying filter data.
