SetWidth method
Sets the start and end width for a polyline or lightweight polyline.
Syntax
object.GetWidth(Index, StartWidth, EndWidth)
Where:
     object is a  Polyline or Lightweight Polyline object;
     Index is a Long integer variable (or value) specifying the polyline segment.
     StartWidth and EndWidth are double-precision variables representing the starting width and ending width, respectively, of the polyline.
Examples...
GetWidth method example
