Split method
Splits the viewport based on the split type specified.
Syntax
object.Split(NumberOfWindows)
Where:
     object is a Viewport or PViewport object;
     NumberOfWIndows is one of the following AcViewportSplitType values:
     acViewport2Horizontal
     acViewport2Vertical
     acViewport3Left
     acViewport3Right
     acViewport3Horizontal
     acViewport3Vertical
     acViewport3Above
     acViewport3Below
     acViewport4
