Class AcadPreferencesPdfOutput
Member of BricscadApp
Use following to obtain a reference to the PreferencesPdfOutput object:
Dim pdfPref As AcadPreferencesPdfOutput
Set pdfPref = ThisDrawing.Application.Preferences.Output.Pdf
The PreferencesPdfOutput object contains PdfOutput settings (stored in registry). The object contains following properties:
Properties |
Application |
EmbeddedTtf |
LayersSetting |
LayoutsToExport |
PaperHeight |
PaperSizeOverride |
PaperWidth |
ShxTextAsGeometry |
SimpleGeomOptimization |
TtfTextAsGeometry |
UsePlotStyles |
ZoomToExtents |
© Menhirs NV. All rights reserved. |
