ContourLinesPerSurface property example
Sub ContourLinesPerSurface_Example()
    ' This example returns the current setting of
    ' ContourLinesPerSurface. It then changes the value, and finally
    ' it resets the value back to the original setting.
    Dim currContourLinesPerSurface As Integer
    Dim newContourLinesPerSurface As Integer
    ' Retrieve the current ContourLinesPerSurface value
    currContourLinesPerSurface = ThisDrawing.Preferences.ContourLinesPerSurface
    MsgBox "The current value for ContourLinesPerSurface is " & currContourLinesPerSurface, vbInformation, "ContourLinesPerSurface Example"
    ' Change the value for ContourLinesPerSurface
    newContourLinesPerSurface = 2001
    ThisDrawing.Preferences.ContourLinesPerSurface = newContourLinesPerSurface
    MsgBox "The new value for ContourLinesPerSurface is " & newContourLinesPerSurface, vbInformation, "ContourLinesPerSurface Example"
    ' Reset ContourLinesPerSurface to its original value
    ThisDrawing.Preferences.ContourLinesPerSurface = currContourLinesPerSurface
    MsgBox "The ContourLinesPerSurface value is reset to " & currContourLinesPerSurface, vbInformation, "ContourLinesPerSurface Example"
End Sub
