EndPoint property example
Sub EndPoint_Example()
' This example adds an arc to the drawing and returns it's StartPoint & EndPoint.
    Dim myArc As AcadArc
    Dim ctrPt(0 To 2) As Double
    ctrPt(0) = 5: ctrPt(1) = 3
    'Add the arc to the .dwg
    Set myArc = ThisDrawing.ModelSpace.AddArc(ctrPt, 2.5, toRadians(15), toRadians(105))
    ThisDrawing.Application.ZoomExtents
    Dim vStartPoint As Variant: vStartPoint = myArc.StartPoint
    Dim vEndtPoint As Variant: vEndtPoint = myArc.EndPoint
    MsgBox "The arc has following start/end coordinates:" & _
    Chr(13) & "start point: " & vStartPoint(0) & ", " & vStartPoint(1) & ", " & vStartPoint(2) & _
    Chr(13) & "  end point: " & vEndtPoint(0) & ", " & vEndtPoint(1) & ", " & vEndtPoint(2)
End Sub
Function toRadians(ByVal inDegrees As Double) As Double
  toRadians = inDegrees * 3.141592 / 180
End Function
