ImageHeight property
Sets or returns the height of the image in current units.
Syntax
doubleVariable = object.ImageHeight
object.ImageHeight = <double>
Where:
     doubleVariable is a double-precision variable (or value) representing the image height (in current units).
     object is an Image object.
Note:
    The .ImageHeight property specifies the height of the Raster in current units, whereas the .Height property specifies the height of the image in pixels.
Examples...
AddImage method example
