MaxCADWindow property example
Sub MaxAutoCADWindow_Example()
Dim myPrefs As AcadPreferences
Set myPrefs = ThisDrawing.Application.Preferences
Dim bCurrMaximizedState As Boolean
bCurrMaximizedState = myPrefs.Display.MaxAutoCADWindow
MsgBox "The current value for MaxAutoCADWindow is " & bCurrMaximizedState
myPrefs.Display.MaxAutoCADWindow = Not (bCurrMaximizedState)
MsgBox "The new value for MaxAutoCADWindow is " & myPrefs.Display.MaxAutoCADWindow
myPrefs.Display.MaxAutoCADWindow = bCurrMaximizedState
MsgBox "The MaxAutoCADWindow value is reset to " & myPrefs.Display.MaxAutoCADWindow
End Sub
© Menhirs NV. All rights reserved. |
