StyleName property example
Sub StyleName_Example()
' This example creates text and adds it to the drawing using the
' AddText method. It then obtains the StyleName property.
    Dim sText As String: sText = "Test string for StyleName property"
    Dim insPt(0 To 2) As Double: insPt(0) = 0: insPt(1) = 9
    Dim dHeight As Double: dHeight = 5
    Dim textObj As AcadText
    Set textObj = ThisDrawing.ModelSpace.AddText(sText, insPt, dHeight)
    textObj.Update
    ThisDrawing.Application.ZoomExtents
    MsgBox "The StyleName is: " & textObj.StyleName
End Sub
