WindowTop property
Specifies the distance from the top edge of the screen to the top edge of the main application window.
Syntax
integerVariable = object.WindowTop
Where:
     integerVariable is a Long integer variable specifying the Top property (in screen pixels).
     object is the Application object.
Examples...
WindowTop property example
