return type |
function |
int |
dlg_new_dialog(LPTSTR szDialogName,int nDialogFileID,void
*pfnDef_Callback,sds_hdlg *hDialog); |
int |
dlg_load_dialog(LPTSTR szFileToLoad,int *nDialogFileID); |
int |
dlg_unload_dialog(int nDialogFileID); |
int |
dlg_start_dialog(sds_hdlg hDialog, int *nMessage); |
int |
dlg_done_dialog(sds_hdlg hDialog,long nMessage); |
int |
dlg_new_positioned_dialog(LPTSTR szDialogName, int
nDialogFileID, void *pfnDef_Callback, int nXPos, int nYPos,
int |
dlg_done_positioned_dialog(sds_hdlg hDialog, int nMessage, int
*nXPos, int *nYPos); |
int |
dlg_term_dialog(void); |
int |
dlg_start_list(sds_hdlg hDialog,LPTSTR szControlKey, int
nChangeAddNew,int nWhichItem); |
int |
dlg_add_list(LPTSTR szAddToList); |
int |
dlg_get_list_string(sds_hdlg hDialog, LPTSTR szControlKey,
LPTSTR szListString, int nStringLength, int nWhichItem); |
int |
dlg_end_list(void); |
int |
dlg_get_attr(sds_hdlg hDialog, LPTSTR szControlKey, LPTSTR
szAttribName, LPTSTR szAttribInfo, int lInfoMaxLength); |
int |
dlg_get_attr_string(sds_htile hControl, LPTSTR szAttribName,
LPTSTR szAttribInfo, long lInfoMaxLength); |
int |
dlg_get_tile(sds_hdlg hDialog,LPTSTR szControlKey,LPTSTR
szControlInfo,long lInfoMaxLength); |
int |
dlg_action_tile(sds_hdlg hDialog,LPTSTR szControlKey,void
*pfnControlFunc); |
int |
dlg_client_data_tile(sds_hdlg hDialog, LPTSTR szControlKey,
void *pApplicationData); |
int |
dlg_dimensions_tile(sds_hdlg hDialog, LPTSTR szControlKey,
short *nWidthLess1, short *nHeightLess1); |
int |
dlg_mode_tile(sds_hdlg hDialog, LPTSTR szControlKey, int
nTileState); |
int |
dlg_set_tile(sds_hdlg hDialog, LPTSTR szControlKey, LPTSTR
szControlInfo); |
int |
dlg_start_image(sds_hdlg hDialog, LPTSTR szControlKey); |
int |
dlg_fill_image(int nULCornerX, int nULCornerY, int nWidthLess1,
int nHeightLess1, int nColor); |
int |
dlg_slide_image(int nULCornerX, int nULCornerY, int
nWidthLess1, int nHeightLess1, LPTSTR szSnapshotName); |
int |
dlg_vector_image(int nXVectStart, int nYVectStart, int
nXVectEnd, int nYVectEnd, int nColor); |
int |
dlg_end_image(void); |
int |
dlg_set_window_text(sds_hdlg hDialog, const TCHAR
*szText); |
int |
dlg_init_dialog(LPCTSTR pathOfBaseDCL = _T("base.dcl"), BOOL
generateErrorLog = false, LPCTSTR pathForErrorLog= _T(""), void*
pCallbackFunction=0); |
int |
dlg_set_audit_level(int auditLevel); |
int |
dlg_set_default_callback(void* pCallbackFunction ); |
