Adding Hatching
Hatching fills a specified area with lines, crosshatching, or other hatch patterns.
The first step in hatching an area is to create the Hatch object. Once this is done, you specify the hatch boundaries.
Creating a Hatch Object
To create a hatch object, use the AddHatch method.
