A point entity consists of a single x-, y-, and z-coordinate location, and is represented by one of several symbols. To create point entities, use the following method:
Creates a PointEntity object and adds it to the drawing. |
To change the appearance of point entities, change the PDMODE and PDSIZE system variables using the SetVariable method.
© Menhirs NV. All rights reserved. |
