Command: XLINE
The Xline command creates infinite lines.
An Infinite Line is a line through a given point, oriented at a specified angle and extending to infinity in both directions. Because infinite lines extend to infinity, they are not calculated as part of the drawing extents. The default method for drawing an infinite line is to select a point and then specify its direction.
Rays and Infinite Lines or sometimes referred to as construction lines.
Drawing infinite lines
Do one of the following:
Click the Infinite
Line tool button () on the Draw 2D toolbar.
Choose Infinite Line in the Draw menu.
Type xline in the command bar, then press Enter.
The command bar reads: Xline: Bisect/Horizontal/Vertical/Angle/Parallel/<Point along line>:
A prompt box displays:
Specify the start point of the infinite line.
The infinite line is created.
A new infinite line through the same start point displays
dynamically.
(option) Specify the direction of the infinite
line.
dynamically.
(option) Repeat step 3 to draw a series of infinite lines, through the same start point.
Right click to stop drawing infinite lines.
(option) Right click to restart.
© Menhirs NV. All rights reserved. |
