Works with Bricscad (Windows) Pro and Platinum, Bricscad (Linux) Pro and Platinum
Sets the geographic location of the drawing.
command bar: geographiclocation
alias: geo
toolbar: Render | ![]()
Settings
Setting |
Latitude |
Sets the latitude of the drawing in decimal format. The valid range is -90 to +90. Positive values represent north latitudes. Either specify a negative value for south latitudes or choose South from the latitude option button. The value is saved to the LATITUDE system variable. |
Longitude |
Sets the longitude of the drawing in decimal format. The valid range is -180 to +180. Positive values represent east longitudes. Either specify a negative value for west longitudes or choose West from the longitude option button. The value is saved to the LONGITUDE system variable. |
Choose Location |
Displays the Choose Geographic Location dialog box.
Timezone |
Choose a time zone from the Time Zone drop down list. The setting is saved to the TIMEZONE system variable. |
North Direction Angle |
Specifies the angle of the sun from north, in the context of the world coordinate system. The setting is saved to the NORTHDIRECTION system variable. |
Render - Calculates a photorealistic image of the 3D model.
Sunproperties - Displays the Sun Properties of the Active Viewport editor in the Drawing Explorer - Lights dialog.
