Enters the license key number (short for "licence enter key").
command bar: licenterkey
transparent: 'licenterkey
: licenterkey
Enter your license information, and then click OK.
Use this command only to change the license number. To view the license number, use the LicProperties command.
A separate license is required for the Classic, Pro and Platinum versions of Bricscad.
Specifies the user's name. |
Specifies the name of the company for which the user works. |
Specifies the license number. |
Specifies the path to the network license file. |
Allows you to pay for a license, and then enter the number in this dialog box. Opens the default Web browser to the Bricsys E-Store page. |
Status - reports on the state of the drawing.
LicProperties - reports the license number and owner.
