Saves drawings in DWG R12 format through a dialog box.
command bar: saveas12
: saveasr12
Displays a dialog box with Save As Type set to "AutoCAD Release 11/12 Drawing (*.dwg)":
To save the drawing in other formats, click the Save As Type droplist.
Selects the drive and folder in which to save the drawing. Click the droplist to access additional locations. |
Specifies the name by which to save the drawing:
Specifies the format of the saved file. Accept the default (AutoCAD 2007 .dwg) or click the droplist to choose another format. There are three basic formats:
Includes a preview image with the drawing file. The preview is a bitmap (raster) image of the drawing's view at the time it is saved. |
Saves the drawing. |
Cancels the command; does not save the drawing. |
Save - saves the current drawing through a dialog box.
QSave - saves the drawing without displaying the Save dialog box.
SaveAll - saves all open drawings.
SaveAs - saves drawings by another name.
Export - exports drawings in a variety of vector and raster formats.
