Works with Bricscad (Windows) Pro and Platinum, Bricscad (Linux) Pro and Platinum
Defines the properties of a section plane entity in the Drawing Explorer - Section Planes dialog.
command bar: sectionplanesettings
menu bar: Tools | Drawing Explorer | Section Planes
Displays a dialog:
Details Panel |
Launches the SectionPlane command to create a new section plane defintion. |
Deletes the currently selected section plane definition. |
Double click the field to rename the section plane. |
Click the checkbox to switch the live section property of a section plane on/off. |
Indicates the state of the section plane. The image below shows a 3D solid (red) and the position and size of the section plane entity (green)
The options are:
Sets the transparency of the cutting plane in the drawing. |
Sets the color of the cutting plane in the drawing. The color of the section line is defined by the Color property of the section plane entity. |
Edit panel If you Select multiple section definitions, you can edit them simultaneously. If a setting is defined differently in the selected section definitions, the setting field reads *varies*. |
Select multiple section plane entities to define their settings simultaneously.
LiveSection - switches the Live Section property of a section plane on or off.
Section - creates section planes of 3D solids; the results are region entities.
SectionPlane - creates a section entity that creates sections of 3D solids, surfaces and meshes.
SectionPlaneToBlock - saves the selected section plane to a 2D cross section / elevation block or a 3D cutaway section block.
