Creates a 3D mesh surface by projecting an entity along a path.
command bar: tabsurf
menu bar: Model | Meshes | Extruded Surface
toolbar: Meshes | 3D Surfaces
: tabsurf
Select entity to extrude: (Choose a single open entity.)
Select line or open polyline for extrusion path: (Pick a line or polyline.)
The entity to be extruded must be open and must be a single entity.
The extrusion path can be a line or open polyline. The polyline need not be a line segment; if a polyarc or multisegment polyline, the extrusion, however, is always "straight," going from the start to the endpoint of the polyline.
The path is a vector, which means its length specifies the length of the surface; its direction specifies the direction of extrusion. The extrusion starts at the entity to be extruded, but goes in the direction indicated by the path.
Specifies the cross-section shape of the extrusion. |
Specifies the length and direction of the extrusion. |
Grips Editing
Mesh-formed tabulated surfaces can be edited directly through grips:
Select the tabsurf. Notice that it has one grip at each vertex.
Drag the grip to move the adjacent faces.
Ai_Dish - draws 3D dishes as mesh surfaces.
RuleSurf - draws ruled surfaces as mesh surfaces.
