Undoes one or more commands; some commands cannot be undone.
command bar: undo
: undo
Undo: Mark/Back to mark/BEgin set/End set/Control/Auto/<Number of steps to undo>: (Enter the number of commands to undo, or enter an option.)
Bricscad reports the commands being undone. For example, enter the Customize and then the Units commands. Enter Undo:
Undo: (UNITS)
Undo: (CUSTOMIZE)
Specifies the number of commands to undo. Enter a number. Commands are undone sequentially; you cannot skip over commands. Some commands cannot be undone, such as Save, Open, and Plot. |
Sets a marker. The Back to mark option undoes all commands to the marker. |
Undoes all commands back to when the marker was set. |
Sets the start to a group that groups the following commands. The Undo command treats the commands in the set as a single undo. |
Ends the group. |
Specifies options; prompts you: Set Undo control: None/One/<All> - enter an option. |
None |
Turns off the undo mechanism. This is useful when disk space is running low, because the undo mechanism uses disk space. |
One |
Limits this command to a single undo. This option turns the Undo command into the U command. |
All |
Turns on the undo mechanism. |
Considers all commands executed by a macro as a single undo. |
U - undoes the last command.
Redo - redoes the last undone command.
Oops - unerases the last erased object, including newly created blocks.
Zoom - utilizes the Previous option to show the previous view.
