Copying Code Examples from the Bricscad
Developer's Reference
Most of the Help topics in the Bricscad
Programmer's Reference contain code examples. You can easily
copy these examples into your own code and then further modify
them, as desired.
To copy a code example from the
- In the Help window, highlight the code you want
to copy.
- In the Help window, choose Edit | Copy. (Or,
press Ctrl + C.)
- Paste the code into your programming
environment, using the appropriate command (usually Edit | Paste,
or Ctrl + V).
- Modify the code, as necessary.
Tell me about...
LISP (LISt
Processing)
DCL (Dialog
Control Language)
DIESEL (Direct Interactively Evaluated
String Expression Language)
COM (Component Object Model)
VBA (Visual
Basic for Applications)
BRX (Bricscad Runtime
eXtension)
DTX (Teigha eXtension)
SDS (deprecated)
© Menhirs NV. All rights reserved. |
