vlisp-optimizer
activates or deactivates the built-in Lisp Optimiser
(vlisp-optimizer enable)
arguments (1):
enable
-when T : activates the built-in Lisp optimiser (default)
-when nil : deactivates the built-in Lisp optimiser for current file (after loading *this* file, it is automatically reset as t)
vle-entget
returns the entity's value for specified DXF groupcode
(vle-entget dxfcode ename)
arguments (2):
dxfcode
DXF groupcode to retrieve the property for
ename
entity to query
vle-entmod
sets the entity's value for specified DXF groupcode
(vle-entmod dxfcode ename value)
arguments (3):
dxfcode
DXF groupcode to set the property for
ename
entity to set the new value
value
new value to be set
vle-alert
(vle-alert title msg flags)
arguments (3):
title
title (caption) text to be displayed
msg
flags
flags to control layout + behaviour of the mesage box (see Windows ::MessageBox() API) also explained in 'vle-extension.lsp' file
vle-startapp
similar to (startapp), runs "cmd" command with 'args' arguments on the OS shell; depending on "mode", it can run synchroneously (inlined) or asynchroneously (parallel)
(vle-startapp cmd [args] [mode])
arguments (3):
cmd
application or command to run
[args]
optional arguments (as string), or NIL if no extra arguments are used
[mode]
-when T runs asnychroneously (inlined) - Bricscad waits until 'cmd' is finished
-when NIL - runs snychroneously (parallel) - Bricscad does not wait until 'cmd' is finished
vle-selectionset->list
returns SelectionSet 'ss' members as a list
(vle-selectionset->list ss)
arguments (1):
ss
members as a list
vle-collection->list
returns a COM (VLA) Collection (i.e. IAcadLayers) 'coll' as a list
(vle-collection->list coll)
arguments (1):
coll
the COM (VLA) collection
vle-start-transaction
starts a database transaction; returns t on success
(vle-start-transaction)
only 1 transaction level is supported, nested calls have no effect
vle-end-transaction
finishes a previously started database transaction
(vle-end-transaction)
must be paired with (vle-start-transaction), even when nested; (vle-end-transaction) on a nested transaction level has no effect, only the outer-most (and only) transaction is finished; Lisp engine automatically ends an active transaction, i.e. in case or error, or when Lisp execution at top-level has finished
vle-displaypause
disabled or enables screen updates during Lisp execution
(vle-displaypause pauseScreen)
arguments (1):
pauseScreen
when T : disables screen updates
when nil : enables screen updates
Lisp engine automatically re-enables screen updates, i.e. in case or error, or when Lisp execution at top-level has finished.
vle-string-split
splits a string into tokens, using delimiter character(s) defined by 'keys'
(vle-string-split keys string)
arguments (2):
keys
string
string to be split
vle-file->list
reads the entire content of a file into a single Lisp list
(vle-file->list filename commentchar)
arguments (2):
filename
file to split
commentchar
defines a comment specifier (if not NIL) - lines starting with that character are treated as comments, and not loaded into list
vle-nth0
returns the nth0 member of list lst
(vle-nth0 lst)
arguments (1):
lst
list
replacement functions for (nth 0 lst)
vle-nth1
returns the nth1 member of list lst
(vle-nth1 lst)
arguments (1):
lst
list
replacement function for (nth 1 lst)
vle-nth2
returns the nth2 member of list lst
(vle-nth2 lst)
arguments (1):
lst
list
replacement function for (nth 2 lst)
vle-nth3
returns the nth3 member of list lst
(vle-nth3 lst)
arguments (1):
lst
list
replacement function for (nth 3 lst)
vle-nth4
returns the nth4 member of list lst
(vle-nth4 lst)
arguments (1):
lst
list
replacement function for (nth 4 lst)
vle-nth5
returns the nth5 member of list lst
(vle-nth5 lst)
arguments (1):
lst
list
replacement function for (nth 5 lst)
vle-nth6
returns the nth6 member of list lst
(vle-nth6 lst)
arguments (1):
lst
list
replacement function for (nth 6 lst)
vle-nth7
returns the nth7 member of list lst
(vle-nth7 lst)
arguments (1):
lst
list
replacement function for (nth 7 lst)
vle-nth8
returns the nth8 member of list lst
(vle-nth8 lst)
arguments (1):
lst
list
replacement function for (nth 8 lst)
vle-nth9
returns the nth9 member of list lst
(vle-nth9 lst)
arguments (1):
lst
list
replacement function for (nth 9 lst)
vle-cdrassoc
returns the (cdr) value of a dotted-pair with 'key'
(vle-cdrassoc key lst)
arguments (2):
key
key
lst
list
replacement for (cdr (assoc key lst))
alias: (vle-get-cdrassoc) (vle-cassoc) (vle-get-cassoc)
vle-set-cdrassoc
changes the (cdr) value of a dotted-pair [key . value] to use new value 'val'
(vle-set-cdrassoc key lst val)
arguments (3):
key
key
lst
list
val
new value
replacement for (subst (cons key val) (assoc key lst) lst)
alias: (vle-set-cassoc)
vle-member
verifies whether 'obj' is contained in 'lst'
(vle-member obj lst)
arguments (2):
obj
element
lst
list
alias: (vle-find)
vle-remove-first
removes the first occurence of 'item' in 'lst', and returns modified list
(vle-remove-first item lst)
arguments (2):
item
item to remove
lst
list
vle-remove-all
removes all occurences of 'item' within 'lst', and returns modified list
(vle-remove-all item lst)
arguments (2):
item
item to remove
lst
list
(vle-remove-all) is identical to (vl-remove) function, included for consistency
vle-remove-last
removes the last item from 'lst' list
(vle-remove-last lst)
arguments (1):
lst
list
replacement for (reverse (cdr (reverse lst)))
vle-remove-nth
removes the item at specified index 'idx' (0-based) from 'lst' list
(vle-remove-nth idx lst)
arguments (2):
idx
index (0-based)
lst
list
alias: (vle-remove-idx)
vle-search
verifies whether 'item' is contained in list 'lst'
(vle-search item lst asIdx)
arguments (3):
item
target item
lst
list
asIdx
when T : returns the index (0-based), or NIL when no match
when nil : returns the sublist starting with item, or NILwhen no match
vle-sublist
returns a sublist of 'lst' starting with item at position 'startidx'
(vle-sublist lst startidx nritems)
arguments (3):
lst
target item
startidx
start index (0-based)
nritems
number of items to include
vle-subst-nth
replaces the item at index 'idx' n list 'lst' with 'val'
(vle-subst-nth lst idx val)
arguments (3):
lst
target item
idx
index (0-based)
val
replacement value
alias: (vle-replace)
vle-stringp
verifies whether 'obj' is of type STRING
(vle-stringp obj)
arguments (1):
obj
object to test
vle-numberp
verifies whether 'obj' is of any number type
(vle-numberp obj)
arguments (1):
obj
object to test
(vle-numberp) is identical to (numberp) function
vle-realp
verifies whether 'obj' is of type REAL
(vle-realp obj)
arguments (1):
obj
object to test
vle-integerp
verifies whether 'obj' is of type INTEGER
(vle-integerp obj)
arguments (1):
obj
object to test
vle-filep
verifies whether 'obj' is of type FILE
(vle-filep obj)
arguments (1):
obj
object to test
vle-enamep
verifies whether 'obj' is of type ENAME
(vle-enamep obj)
arguments (1):
obj
object to test
vle-vlaobjectp
verifies whether 'obj' is of type VLA-OBJECT
(vle-vlaobjectp obj)
arguments (1):
obj
object to test
vle-variantp
verifies whether 'obj' is of type VARIANT
(vle-variantp obj)
arguments (1):
obj
object to test
vle-safearrayp
verifies whether 'obj' is of type SAFEARRAY
(vle-safearrayp obj)
arguments (1):
obj
object to test
vle-stringp
(vle-stringp obj)
arguments (1):
obj
object to test
