Delete method
Deletes a specified object, such as a drawing entity or a block, layer, or linetype.
Syntax
object.Delete
Where:
     object is the name of the object to be deleted. The object may be one of the following:
All Drawing Objects, Block, Layer, Linetype, Pviewport, SelectionSet, TextStyle, UCS, View, Viewport.
Examples...
Delete method example
