Rotates the selection set and all its members about an axis formed by two points. The direction of the axis is from point1 to point2.
Syntax
Where:
object is a Bricscad entity;
Point1 is a Variant (three-element array of doubles) representing the first point of the axis about which objects will be rotated;
Point2 is a Variant (three-element array of doubles) representing the second point of the axis about which objects will be rotated;
RotationAngle is a double-precision variable (or value) representing the angle in radians.
Examples...
© Menhirs NV. All rights reserved. |
