Length/Closed Properties example
Sub Length_Closed_Example()
' This example adds a lightweight polyline and
' querries it's .Length and .Closed properties.
    Dim myLWP As AcadLWPolyline
    'LWpolyline expects an array of 2D coordinates (only x and y)
    Dim myPoints(0 To 5) As Double
    myPoints(0) = 0: myPoints(1) = 0
    myPoints(2) = 3: myPoints(3) = 0
    myPoints(4) = 3: myPoints(5) = 4
    Set myLWP = ThisDrawing.ModelSpace.AddLightWeightPolyline(myPoints)
    myLWP.Closed = True
    myLWP.Update
    ThisDrawing.Application.ZoomExtents
    MsgBox "The length of the new polyline is: " & myLWP.Length
    MsgBox "The Closed property is: " & myLWP.Closed
    myLWP.Closed = False
    myLWP.Update
    MsgBox "The length of the polyline is: " & myLWP.Length
End Sub
