Sub Name_Example() ' This example creates a new layer. It then changes the name of that layer. Dim layerObj As AcadLayer Set layerObj = ThisDrawing.Layers.Add("NewLayer") Dim sLayerName As String sLayerName = layerObj.Name MsgBox "A new layer was created with the name: " & sLayerName layerObj.Name= "TEST" sLayerName = layerObj.Name MsgBox "The new name of the layer is: " & layerObj.Name End Sub
© Menhirs NV. All rights reserved. |
