Normal property example
Sub Normal_Example()
' This example creates an circle and determines its Normal property.
' It then creates a vector and uses it to reset the Normal property.
     Dim myCircle As AcadCircle
     Dim ctrPt(0 To 2) As Double
     ctrPt(0) = 5: ctrPt(1) = 3
     'Add the arc to the .dwg
     Set myCircle = ThisDrawing.ModelSpace.AddCircle(ctrPt, 5)
     ' Display the entity
     myCircle.Update
     ThisDrawing.Application.ZoomExtents
     Dim vNormal As Variant
     vNormal = myCircle.Normal
     MsgBox "Circle's normal Vector:" & _
     Chr(13) & "x = " & vNormal(0) & _
     Chr(13) & "y = " & vNormal(1) & _
     Chr(13) & "z = " & vNormal(2)
     Dim vecNormal(0 To 2) As Double
     vecNormal(0) = 0.5: vecNormal(1) = -0.8
     myCircle.Normal = vecNormal
     myCircle.Update
     MsgBox "Circle's normal Vector is now:" & _
End Sub
