Command: TOOLPALETTES
On a tool palette you can add blocks, hatches and commands in a tabbed window.
Drag a tool from the palette to the graphic screen to launch the related tool.
Tool
Palettes (Internet connection needed)
Do one of the following:
Hover over a toolbar (Windows) or an empty toolbar area (Windows and Linux), then right click and choose Tool Palettes Bar in the context menu.
Type toolpalettes in the command bar, then press Enter.
Click the tool palette tab.
Right click and choose View Options... in the
context menu.
The View Options dialog displays.
Select either Icon with text or Icon only.
Choose either Current Palette or All Palettes from the Apply to list button.
Click the OK button to confirm.
Move the cursor to the icon area of the
Tool Palettes Bar, then right
click.
A context menu displays:
Choose New Palette in
the context menu.
A new tab is added.
Type a name for the new palette in the Name field.
click.
Choose Import Palette in the context menu.
On the Import Palette dialog select a palette file (*.btc) in the Palettes subfolder.
Click the Open button
or double click to import the palette.
The palette is added in a new tab.
Right click and choose Rename Palette in the context menu.
Type a new name for the palette in the Name field.
Press Enter to confirm.
Right click and choose Delete Palette in the context menu.
Click the OK button on the Confirm Palette Deletion box.
Select the palette you want to add a hatch pattern to.
Open the Hatch and Gradient dialog box.
Select either Predefined or Custom from the Type list button.
Double click the Swatch field on the Hatch
The Hatch Pattern Palette
displays.
Select the hatch pattern you want to add, then right click.
Choose Add to Current Tool
Palette.
The hatch pattern is added on the current tool palette.
(option) Repeat steps 5 and 6 to add more hatch patterns.
Blocks can be added from the current drawing or from any drawing.
Choose Drawing Explorer - Blocks in the Tools menu.
On the Drawing Explorer - Blocks dialog box select the block or blocks you want to add.
Right click and choose Export to Tool Palettes in the context menu.
If not already available, add the containing folder to the Folders list on the Drawing Explorer - Drawings dialog box.
Select the drawing in the containing folder on the Drawing Explorer - Drawings dialog box.
Click the Expand icon (+) of the containing
drawing.
The Blocks icon of the drawing
displays.
Click the Blocks icon
of the containing drawing.
The blocks in the drawing display in the Details pane.
Select the block or blocks you want to add.
Right click and choose Add to Current Tool Palette in the context menu.
Right click and choose Add to Current Toolpalette as block in the context menu.
Choose Customize in the Tools menu.
Under Available Tools on the Customize dialog, expand the containing toolbox, then select the command in the commands list.
NOTE |
See the topic Creating Custom Tools to create your own tools, which you can then add to a tool palette. |
General procedure to edit a tool on a tool palette:
Right click the tool, then choose Properties in the context menu.
The Tool Properties dialog box
displays.
Edit the tool properties.
To move a too from one palette to another, do the following:
Select the tool on the source palette, then right click and choose Cut in the context menu.
Select the target palette.
Right click and choose Paste in the context menu.
The tool is added at the bottom of the palette.
Select the tool, then right click and choose Delete in the context menu.
Click the OK button on the Confirm Tool Deletion box.
