Command: DIMANGULAR
Angular dimensions annotate the angle measured between two lines, two linear segments of a polyline or the angle of a circular arc. You can also dimension an angle by selecting an angle vertex and two endpoints.
Starting from an existing angular dimension, you can add a baseline dimension or a continued dimension. An angular baseline dimension inserts an additional dimension from a common first extension line origin. An angular continued dimension continues an angular dimension from the second extension line of a previous angular dimension.
angular dimension measured between two lines |
angular dimension of an arc |
angular dimension defined by a vertex and two endpoints |
angular baseline dimensions |
angular continued dimensions |
To dimension an angle between two lines
Do one of the following
Click the Angular tool button (
) on the Dimensions toolbar.
Choose Angular in the Dimensions menu.
Type dimangular in the command bar, then press Enter.
The command bar reads: Press Enter to specify angle/<select line, arc, or circle>:
Select the first line or line segment.
The command bar reads: Other line for angular dimension:
Select the second line or line segment.
The angular dimension displays dynamically.
The command bar reads: Angle/Text/<Location of dimension
arc>:
Do one of the following:
Position the dimension arc.
Type A and press Enter to define the angle of the dimension text, then position the dimension arc.
Type T and press Enter to modify the dimension text, then position the dimension arc.
To dimension an angle encompassed by an arc
Select the arc.
arc>:
To create an angular dimension defined by a vertex and two endpoints
Right click or press Enter.
The command bar reads: Vertex of angle.
Specify the vertex of the angle.
The command bar reads: first side of angle.
Specify the endpoint of the first side of the
angle.
The command bar reads: Other side of angle.
Specify the endpoint of the second side of the
angle.
arc>:
