Command: SCALE
The Scale command resizes a selection set in relation to a base point. You can specify the scale factor by selecting a base point and a length or by typing an explicit scale factor in the command bar. The scale factor can also be defined with respect to a base scale factor. E.g. when the base scale factor is 2 and the new scale is 3, the new size is 3/2 of the original. The base scale and the new scale can also be defined graphically in the drawing.
The Copy option of the Grips Editing commands allows to create multiple copies of the entities being stretched, moved, rotated, mirrored or scaled.
Do one of the following:
Click the Scale
tool button () on the Modify toolbar
Choose Scale in the Modify menu.
Type scale or SC in the command bar.
The command bar reads: Select entities to scale:
Select the entities, then right click or press Enter.
The command bar reads: Base point:
Specify the base point for the scaling.
The selection set scales dynamically.
The command bar reads: Base scale/<Scale Factor>:
Type the scale factor in the command bar and press
Enter.
The selection set is scaled.
NOTE |
The length of the vector between the base point and the current cursor position is used as the dynamic scale factor in step 3. |
Scaling an entity using a base scale
Select the entity.
Click the Scale
Specify the base point (1).
The command bar reads: Base Scale/<Scale Factor>:
Choose Base in the
prompt menu of type B and press
Enter.
The command bar reads: Base scale <1>:
Click point 1, then point 2 to define the base
scale.
The pentagon scales dynamically.
Click point 3.
The edge of the pentagon now equals the side of the square.
© Menhirs NV. All rights reserved. |
