Command: PEDIT
The Width option of the Edit Polyline tool applies a uniform width to the entire entity, while the Taper option tapers the polyline uniformly along its entire length.
To apply a uniform width to a polyline
Do one of the following:
Click the Edit
Polyline tool button () on the Modify toolbar.
Choose Edit Polyline in the Modify menu.
Type editpline or pedit in the command window, then press Enter.
The command bar reads: Select polyline to edit.
Select the polyline.
The command bar reads: Edit polyline: Edit vertices/Close (or
Open)/Decurve/Fit/Join/Linetype-Mode/Reverse/Spline/Taper/Width/Undo/<eXit>:
A prompt menu displays.
Choose Width in the
prompt menu or type W and press
Enter.
The command bar reads: Enter new width for all segments:
Type a new width in the command bar and press
Enter.
The new width is applied to the entire polyline.
Continue editing the selected polyline.
Choose Done in the prompt menu or press Enter to conclude the Edit Polyline tool.
To taper a polyline uniformly along its length
Click the Edit
Choose Taper in the
prompt menu or type T and press
Enter.
The command bar reads: Enter new starting polyline width
<current starting width>::
Type a new starting width in the command bar and
press Enter.
The command bar reads: Enter new ending polyline width <current
ending width>:
Type a new ending width in the command bar and
press Enter.
The polyline is tapered uniformly along its length.
© Menhirs NV. All rights reserved. |
