BricsCAD runs flawlessly on Windows. However, when running the installer or when entering a license key, depending on your User Account Control Settings, Windows might complain about insufficient access rights. Therefore it is important to launch such operations using the Run as administrator option.
Using the 'Run as administrator option'
In Windows Explorer select the executable (e.g. bricscad.exe or BricsCAD-Vxx.x.xx-x-en_US.exe).
Right click, then choose Run as administrator from the context menu.
