Works with BricsCAD (Windows) Platinum, BricsCAD (Linux) Platinum
Displays the 3D Constraints bar.
command bar: dmconstraintsbar
menu bar: Parametric | 3D Constraints Bar
toolbar: 3D Constraints | ![]()
: dmConstraintsBar
By default the 3D Constraints bar is docked a the right hand side of the BricsCAD application window, below the Properties bar.
Icon |
Groups the 3D constraints by entity (body). |
Groups the 3D constraints by constraint type. |
Sorts the 3D constraints alphabetically. |
Current name of the entity (body). |
Current value of a dimensional constraint. Click the field to edit. |
Context Menu
Right click a constraint, then click Delete to delete the constraint. |
DmConstraint3D - applies geometric relationships and dimensional constraints between subentities (faces, surfaces, edges, ...) of 3D entities.
DmUpdate - Forces 3d constraints to update.
DmCoincident3d - applies a coincident constraint between two edges, two faces or an edge and a face of two different solids.
DmConcentric3d - applies a concentric constraint between two cylindrical, spherical or conical surfaces.
DmFix3d - Applies a fixed constraint to a solid or to an edge or a face of a solid.
DmParallel3d - applies a parallel constraint between two faces of a solid or of different solids.
DmPerpendicular3d - applies a perpendicular constraint between two faces of a solid or of different solids.
DmRigidSet3d - Allows to define a set of entities or subentities as a rigid body.
DmTangent3d - applies a tangent constraint between a face and a curved surface of different solids.
DmAngle3d - applies an angle constraint between two faces of a solid or of different solids.
DmDistance3d - applies a distance constraint between two subentities of a solid or of different solids.
DmRadius3d - applies a radius constraint to cylindrical surfaces or circular edges.
