Works with BricsCAD (Windows) Classic, Pro and Platinum
Inserts foreign (non-BricsCAD) objects into drawings
command bar: insertobj
alias: io
menu bar: Insert | Insert Object
: insertobj
Choose an object type, and then click OK.
BricsCAD opens the related application; create an object, such as a spreadsheet or diagram.
When done, choose File | Close and Return to Drawing. The object appears in the upper left corner of the drawing.
Creates a new object by opening an application. These objects are also known as OLE objects, short for Object Linking and Embedding. |
Displays a different set of options:
Specifies the file name of the object. |
Displays the Browse dialog box; choose a file, and then click Open. |
Toggles linkage to the source document:
Displays the object as an icon. The icon is related to the document type. |
Displays the Change Icon dialog box:
Choose another icon, edit the label text, and then click OK. |
Grips Editing
Select an OLE object by clicking on its frame. Eight grips appear:
Grips Editing |
Resize |
Resizes the object by dragging any of the four corner grips. The aspect ratio is maintained. |
Stretch |
Stretches the object by dragging any of the four midpoint grips. The aspect ratio is not maintained. |
Erase |
Erases the selected object when the Del button is pressed. |
OleLinks - adjusts links of OLE entities embedded in or linked to drawings
OleOpen - creates package files of OLE entities
PasteSpec - pastes entities in several formats.
Insert - inserts DWG files in drawings.
ImageAttach - attaches raster images to drawings.
XAttach - attaches DWG files to drawings.
