Works with BricsCAD (Windows) Pro and Platinum, BricsCAD (Linux) Pro and Platinum
Displays the Drawing Explorer - Lights dialog window.
command bar: lightlist
alias: LL
menu bar: Tools | Drawing Explorer | Lights...
toolbar: Lights | ![]()
Menu bar |
Icon |
New |
Edit | New |
Starts the LIGHT command. |
Delete |
Edit | Delete |
Deletes the selected lights. |
Select in drawing |
Edit | Select lights in drawing |
Selects the light's glyph in the drawing. |
Rename |
Edit | Rename |
Edit the name of the light. |
Select all |
Edit | Select all |
Selects all lights in the light list. Choose Select in drawing to select the glyphs of all lights in the drawing. |
ON |
Indicates the light is currently switched off. Click to turn the light on. |
OFF |
Indicates the light is currently switched on. Click to turn the light off. |
Light: Creates a new light.
Render: Calculates a photorealistic image of the 3D model.
Sunproperties: Displays the Sun Properties of the Active Viewport editor in the Drawing Explorer - Lights dialog.
